Arduino: 1.6.6 Hourly Build 2015/10/26 06:42 (Windows XP), Плата:"Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS)"
Внимание: platform.txt из ядра 'ESP8266 Modules' содержит устаревшие recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", автоматически преобразовано в recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Ожидайте обновления ядра.
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library ESP8266httpUpdate is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Hash is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Ticker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
In file included from f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:29:0:
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.h:25:0: warning: "UDP_TX_PACKET_MAX_SIZE" redefined [enabled by default]
[HASHTAG]#define[/HASHTAG] UDP_TX_PACKET_MAX_SIZE 24
In file included from f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\utility/wifi_drv.h:26:0,
from f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:26:
C:\Documents and Settings\Admin\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src/WiFiUdp.h:28:0: note: this is the location of the previous definition
[HASHTAG]#define[/HASHTAG] UDP_TX_PACKET_MAX_SIZE 8192
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.h:27:7: error: redefinition of 'class WiFiUDP'
class WiFiUDP : public UDP {
C:\Documents and Settings\Admin\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src/WiFiUdp.h:32:7: error: previous definition of 'class WiFiUDP'
class WiFiUDP : public UDP, public SList<WiFiUDP> {
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In constructor 'WiFiUDP::WiFiUDP()':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:35:22: error: class 'WiFiUDP' does not have any field named '_sock'
WiFiUDP::WiFiUDP() : _sock(NO_SOCKET_AVAIL) {}
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual uint8_t WiFiUDP::begin(uint16_t)':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:45:9: error: '_sock' was not declared in this scope
_sock = sock;
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:46:9: error: '_port' was not declared in this scope
_port = port;
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::available()':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:56:7: error: '_sock' was not declared in this scope
if (_sock != NO_SOCKET_AVAIL)
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual void WiFiUDP::stop()':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:66:8: error: '_sock' was not declared in this scope
if (_sock == NO_SOCKET_AVAIL)
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:69:26: error: '_sock' was not declared in this scope
ServerDrv::stopClient(_sock);
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::beginPacket(IPAddress, uint16_t)':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:88:7: error: '_sock' was not declared in this scope
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:90:7: error: '_sock' was not declared in this scope
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::endPacket()':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:101:32: error: '_sock' was not declared in this scope
return ServerDrv::sendUdpData(_sock);
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual size_t WiFiUDP::write(const uint8_t*, size_t)':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:111:27: error: '_sock' was not declared in this scope
ServerDrv::insertDataBuf(_sock, buffer, size);
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::read()':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:125:23: error: '_sock' was not declared in this scope
ServerDrv::getData(_sock, &b);
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::read(unsigned char*, size_t)':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:137:31: error: '_sock' was not declared in this scope
if (!ServerDrv::getDataBuf(_sock, buffer, &size))
eek()':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:152:22: error: '_sock' was not declared in this scope
ServerDrv::getData(_sock, &b, 1);
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual IPAddress WiFiUDP::remoteIP()':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:167:25: error: '_sock' was not declared in this scope
WiFiDrv::getRemoteData(_sock, _remoteIp, _remotePort);
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual uint16_t WiFiUDP::remotePort()':
f:\Progger\AVR\Arduino\arduino165\arduino-nightly\libraries\WiFi\src\WiFiUdp.cpp:177:25: error: '_sock' was not declared in this scope
exit status 1
Ошибка компиляции.
Неверная библиотека найдена в C:\Documents and Settings\Admin\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\esp8266: C:\Documents and Settings\Admin\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\esp8266
Это сообщение будет содержать больше информации чем
"Отображать вывод во время компиляции"
включено в Файл > Настройки
