#include <Arduino.h>
#include "FS.h"
#include <LittleFS.h>
/* You only need to format LittleFS the first time you run a
   test or else use the LITTLEFS plugin to create a partition
   https://github.com/lorol/arduino-esp32littlefs-plugin
   If you test two partitions, you need to use a custom
   partition.csv file, see in the sketch folder */
//#define TWOPART
#define FORMAT_LITTLEFS_IF_FAILED true
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
    Serial.printf("Listing directory: %s\r\n", dirname);
    File root = fs.open(dirname);
    if(!root){
        Serial.println("- failed to open directory");
        return;
    if(!root.isDirectory()){
        Serial.println(" - not a directory");
        return;
    File file = root.openNextFile();
    while(file){
        if(file.isDirectory()){
            Serial.print("  DIR : ");
            Serial.println(file.name());
            if(levels){
                listDir(fs, file.path(), levels -1);
            Serial.print("  FILE: ");
            Serial.print(file.name());
            Serial.print("\tSIZE: ");
            Serial.println(file.size());
void createDir(fs::FS &fs, const char * path){
    Serial.printf("Creating Dir: %s\n", path);
    if(fs.mkdir(path)){
        Serial.println("Dir created");
        Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char * path){
    Serial.printf("Removing Dir: %s\n", path);
    if(fs.rmdir(path)){
        Serial.println("Dir removed");
        Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char * path){
    Serial.printf("Reading file: %s\r\n", path);
    File file = fs.open(path);
    if(!file || file.isDirectory()){
        Serial.println("- failed to open file for reading");
        return;
    Serial.println("- read from file:");
    while(file.available()){
        Serial.write(file.read());
    file.close();
void writeFile(fs::FS &fs, const char * path, const char * message){
    Serial.printf("Writing file: %s\r\n", path);
    File file = fs.open(path, FILE_WRITE);
    if(!file){
        Serial.println("- failed to open file for writing");
        return;
    if(file.print(message)){
        Serial.println("- file written");
        Serial.println("- write failed");
    file.close();
void appendFile(fs::FS &fs, const char * path, const char * message){
    Serial.printf("Appending to file: %s\r\n", path);
    File file = fs.open(path, FILE_APPEND);
    if(!file){
        Serial.println("- failed to open file for appending");
        return;
        Serial.println("- message appended");
        Serial.println("- append failed");
    file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2){
    Serial.printf("Renaming file %s to %s\r\n", path1, path2);
    if (fs.rename(path1, path2)) {
        Serial.println("- file renamed");
        Serial.println("- rename failed");
void deleteFile(fs::FS &fs, const char * path){
    Serial.printf("Deleting file: %s\r\n", path);
    if(fs.remove(path)){
        Serial.println("- file deleted");
        Serial.println("- delete failed");
// SPIFFS-like write and delete file, better use #define CONFIG_LITTLEFS_SPIFFS_COMPAT 1
void writeFile2(fs::FS &fs, const char * path, const char * message){
    if(!fs.exists(path)){
        if (strchr(path, '/')) {
            Serial.printf("Create missing folders of: %s\r\n", path);
            char *pathStr = strdup(path);
            if (pathStr) {
                char *ptr = strchr(pathStr, '/');
                while (ptr) {
                    *ptr = 0;
                    fs.mkdir(pathStr);
                    *ptr = '/';
                    ptr = strchr(ptr+1, '/');
            free(pathStr);
    Serial.printf("Writing file to: %s\r\n", path);
    if(!file){
        return;
    file.close();
void deleteFile2(fs::FS &fs, const char * path){
    Serial.printf("Deleting file and empty folders on path: %s\r\n", path);
    if (pathStr) {
        char *ptr = strrchr(pathStr, '/');
        if (ptr) {
            Serial.printf("Removing all empty folders on path: %s\r\n", path);
        while (ptr) {
            *ptr = 0;
            fs.rmdir(pathStr);
        free(pathStr);
void testFileIO(fs::FS &fs, const char * path){
    Serial.printf("Testing file I/O with %s\r\n", path);
    static uint8_t buf[512];
    size_t len = 0;
    if(!file){
        return;
    size_t i;
    Serial.print("- writing" );
    uint32_t start = millis();
    for(i=0; i<2048; i++){
        if ((i & 0x001F) == 0x001F){
          Serial.print(".");
        file.write(buf, 512);
    Serial.println("");
    uint32_t end = millis() - start;
    Serial.printf(" - %u bytes written in %u ms\r\n", 2048 * 512, end);
    file.close();
    start = millis();
    end = start;
    i = 0;
    if(file && !file.isDirectory()){
        len = file.size();
        size_t flen = len;
        start = millis();
        Serial.print("- reading" );
        while(len){
            size_t toRead = len;
            if(toRead > 512){
                toRead = 512;
            file.read(buf, toRead);
            if ((i++ & 0x001F) == 0x001F){
              Serial.print(".");
            len -= toRead;
        Serial.println("");
        Serial.printf("- %u bytes read in %u ms\r\n", flen, end);
        file.close();
void setup(){
#ifdef TWOPART
    if(!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED, "/lfs2", 5, "part2")){
    Serial.println("part2 Mount Failed");
    return;
    appendFile(LittleFS, "/hello0.txt", "World0!\r\n");
    readFile(LittleFS, "/hello0.txt");
    LittleFS.end();
    Serial.println( "Done with part2, work with the first lfs partition..." );
#endif
    if(!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED)){
        Serial.println("LittleFS Mount Failed");
        return;
    Serial.println( "SPIFFS-like write file to new path and delete it w/folders" );
    writeFile2(LittleFS, "/new1/new2/new3/hello3.txt", "Hello3");
    listDir(LittleFS, "/", 3);
    deleteFile2(LittleFS, "/new1/new2/new3/hello3.txt");
    createDir(LittleFS, "/mydir");
    writeFile(LittleFS, "/mydir/hello2.txt", "Hello2");
    listDir(LittleFS, "/", 1);
    deleteFile(LittleFS, "/mydir/hello2.txt");
    removeDir(LittleFS, "/mydir");
    writeFile(LittleFS, "/hello.txt", "Hello ");
    appendFile(LittleFS, "/hello.txt", "World!\r\n");
    readFile(LittleFS, "/hello.txt");
    renameFile(LittleFS, "/hello.txt", "/foo.txt");
    readFile(LittleFS, "/foo.txt");
    deleteFile(LittleFS, "/foo.txt");
    testFileIO(LittleFS, "/test.txt");
    deleteFile(LittleFS, "/test.txt");
    Serial.println( "Test complete" );
void loop(){
