Обрывается прошивка
Если и после этого показывает ошибку c_sum_err, попробуйте переписать память, залив в нее АТ прошивку, как это сделать есть на форуме.
Step7
AT прошивку ставил ESP8266_NonOS_AT_Bin_V1.7.1 AT пишеш в терминале тишина
Step7
load config ...
EFUSE_MODE: 1
load config ...
test label: Download Panel 1
self.num: 1
init finished
_COM:  6
ESP_ROM_BAUD :  115200
EFUSE_MODE: 1
test baudrate:  115200
test baudrate selection:   4
test label: Download Panel 2
self.num: 2
init finished
_COM:  6
EFUSE_MODE: 1
test baudrate:  46080
test baudrate selection:   2
test label: Download Panel 3
self.num: 3
init finished
_COM:  6
EFUSE_MODE: 1
test baudrate:  9600
test baudrate selection:   0
test label: Download Panel 4
self.num: 4
init finished
_COM:  6
EFUSE_MODE: 1
test baudrate:  9600
test label: Download Panel 5
self.num: 5
init finished
_COM:  6
EFUSE_MODE: 1
test baudrate:  9600
test label: Download Panel 6
self.num: 6
init finished
_COM:  6
EFUSE_MODE: 1
test baudrate:  9600
test label: Download Panel 7
self.num: 7
init finished
_COM:  6
EFUSE_MODE: 1
test baudrate:  9600
test label: Download Panel 8
self.num: 8
init finished
_COM:  6
EFUSE_MODE: 1
test baudrate:  9600
tout as adc
RF option applied...
test offset :  1032192 0xfc000
case ok
test offset :  1040384 0xfe000
case ok
test offset :  0 0x0
case ok
test offset :  4096 0x1000
case ok
test offset :  528384 0x81000
case ok
(True, [[u'C:\\Users\\Step\\Desktop\\esp8266\\ESP8266_NonOS_AT_Bin_V1.7.1\\ESP8266_NonOS_AT_Bin_V1.7.1\\bin\\boot_v1.7.bin', 0], [u'C:\\Users\\Step\\Desktop\\esp8266\\ESP8266_NonOS_AT_Bin_V1.7.1\\ESP8266_NonOS_AT_Bin_V1.7.1\\bin\\at\\1024+1024\\user1.2048.new.5.bin', 4096], [u'C:\\Users\\Step\\Desktop\\esp8266\\ESP8266_NonOS_AT_Bin_V1.7.1\\ESP8266_NonOS_AT_Bin_V1.7.1\\bin\\at\\1024+1024\\user2.2048.new.5.bin', 528384], [u'C:\\Users\\Step\\Desktop\\esp8266\\ESP8266_NonOS_AT_Bin_V1.7.1\\ESP8266_NonOS_AT_Bin_V1.7.1\\bin\\esp_init_data_default_v08.bin', 1032192], [u'C:\\Users\\Step\\Desktop\\esp8266\\ESP8266_NonOS_AT_Bin_V1.7.1\\ESP8266_NonOS_AT_Bin_V1.7.1\\bin\\blank.bin', 1040384]])
rep_path : C:\Users\Step\Desktop\esp8266\FLASH_DOWNLOAD_TOOLS_v2.4_150924\FLASH_DOWNLOAD_TOOLS_v2.4_150924\bin_tmp\downloadPanel1
size_speed : 20
test fpath: C:\Users\Step\Desktop\esp8266\ESP8266_NonOS_AT_Bin_V1.7.1\ESP8266_NonOS_AT_Bin_V1.7.1\bin\_temp_by_dltool/downloadPanel1
test fname: C:\Users\Step\Desktop\esp8266\ESP8266_NonOS_AT_Bin_V1.7.1\ESP8266_NonOS_AT_Bin_V1.7.1\bin\_temp_by_dltool/downloadPanel1\boot_v1.7.bin_rep
mode :     speed:
write bin :  C:\Users\Step\Desktop\esp8266\ESP8266_NonOS_AT_Bin_V1.7.1\ESP8266_NonOS_AT_Bin_V1.7.1\bin\_temp_by_dltool/downloadPanel1\boot_v1.7.bin_rep
test fname: C:\Users\Step\Desktop\esp8266\ESP8266_NonOS_AT_Bin_V1.7.1\ESP8266_NonOS_AT_Bin_V1.7.1\bin\_temp_by_dltool/downloadPanel1\esp_init_data_default_v08.bin_rep
mode :     speed:
write bin :  C:\Users\Step\Desktop\esp8266\ESP8266_NonOS_AT_Bin_V1.7.1\ESP8266_NonOS_AT_Bin_V1.7.1\bin\_temp_by_dltool/downloadPanel1\esp_init_data_default_v08.bin_rep
test running : False
serial port opened
Connecting...
chip sync ok!
0x3ff00050: 424d0000
0x3ff00054: 02002de8
0x3ff00058: b300b000
0x3ff0005c: 002cf432
EFUSE MODE : 1
reg0:424d0000
reg1:02002de8
reg2:b300b000
reg3:002cf432
check_err_0: 0b
check_err_1: 00
check_err_2: 00
check_err_3: 02
check_err_4: 0b
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 179
target crc val: 179
CRC IN MODE 1:
crc_calc_res: 77
target crc val: 77
EFUSE LOG:
EFUSE LOG:
REG0:424D0000
REG1:02002DE8
REG2:b300b000
REG3:002CF432
EFUSE NORMAL MODE
EFUSE CHECK PASS...
reg2>>13: 5
48bit mac
debug:
2c f4 32 2d e8 42
ID FOR XM: 0B 30 00 00 00 04 D0 00
XM_ID: 0B3000000004D000
crc_efuse_4bit: 0
crc_calc_4bit: 3
48bit mac
MAC AP : 2E-F4-32-2D-E8-42
MAC STA: 2C-F4-32-2D-E8-42
get mac res:  True
('tttest uuuuuuuuuuart : uart reg: ', 457)
(' baudrate: ', 115200)
get crystal: 26323200
head: 0 ;total: 0
erase size : 0
get flash id : 0x1914405e
manufacturer_id: 0x5e
device_id: 0x4014
vendor: 94
mode: 64
mode: 0
sel.freq: 26000000
tttttest crystal : 1
filename:  C:\Users\Step\Desktop\esp8266\FLASH_DOWNLOAD_TOOLS_v2.4_150924\FLASH_DOWNLOAD_TOOLS_v2.4_150924\bin_tmp\downloadPanel1\boot_v1.7.bin_rep
offset :  0
filename:  C:\Users\Step\Desktop\esp8266\FLASH_DOWNLOAD_TOOLS_v2.4_150924\FLASH_DOWNLOAD_TOOLS_v2.4_150924\bin_tmp\downloadPanel1\user1.2048.new.5.bin
offset :  4096
filename:  C:\Users\Step\Desktop\esp8266\FLASH_DOWNLOAD_TOOLS_v2.4_150924\FLASH_DOWNLOAD_TOOLS_v2.4_150924\bin_tmp\downloadPanel1\user2.2048.new.5.bin
offset :  528384
filename:  C:\Users\Step\Desktop\esp8266\FLASH_DOWNLOAD_TOOLS_v2.4_150924\FLASH_DOWNLOAD_TOOLS_v2.4_150924\bin_tmp\downloadPanel1\esp_init_data_default_v08.bin_rep
offset :  1032192
filename:  C:\Users\Step\Desktop\esp8266\FLASH_DOWNLOAD_TOOLS_v2.4_150924\FLASH_DOWNLOAD_TOOLS_v2.4_150924\bin_tmp\downloadPanel1\blank.bin
offset :  1040384
Erasing flash...
head: 1 ;total: 1
erase size : 4096
mode: 0
sel.freq: 26000000
Writing at 0x00000c00... (0 %)
Leaving...
Erasing flash...
head:  15 ;total: 111
erase size :  393216
Writing at 0x0006f800... (49 %)
Leaving...
Erasing flash...
erase size :  393216
Writing at 0x000ef800... (99 %)
Leaving...
Erasing flash...
head: 1 ;total: 1
erase size : 4096
Writing at 0x000fc000... (99 %)
Leaving...
Erasing flash...
head: 1 ;total: 1
erase size : 4096
Writing at 0x000fec00... (99 %)
Leaving...
com closed
AT прошивку ставил ESP8266_NonOS_AT_Bin_V1.7.1 AT прошивал ESP_DOWNLOAD_TOOL_V2.4
Step7
Вот настройки какие выставлял при прошивке!Люди добрые помогите оживить модуль!
Step7
Вот что ресет говорит после прошивке
18:53:14.373 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
18:53:14.373 ->
18:53:14.373 -> load 0x40100000, len 32300, room 16
18:53:14.420 -> tail 12
18:53:14.420 -> chksum 0xef
18:53:14.420 -> ho 0 tail 12 room 4
18:53:14.420 -> load 0x00000000, len 0, room 12
18:53:14.420 -> tail 0
18:53:14.467 -> load 0x00000000, len 0, room 4
18:53:14.467 -> tail 0
18:53:14.467 -> chksum 0xef
18:53:14.467 -> csum 0xef
18:53:14.467 -> csum err
18:53:14.467 -> ets_main.c
Step7
Для решения проблемы нужно сменить режим работы Flash Mode на DOUT
А можете показать где у меня ошибка ?
Ошибка не у вас, а в подсчете контрольной суммы.
На форуме это часто встречается, достаточно почитать.
