11:50:37 **** Build of configuration Default for project HttpServer_Bootstrap ****
mingw32-make.exe -f C:/Sming-master/HttpServer_Bootstrap/Makefile all
C+ ../Sming/system/stringconversion.cpp
CC ../Sming/system/flashmem.c
C+ ../Sming/system/esp_cplusplus.cpp
C+ ../Sming/Wiring/WShift.cpp
C+ ../Sming/Wiring/WMath.cpp
C+ ../Sming/Wiring/SplitString.cpp
C+ ../Sming/Wiring/WString.cpp
C+ ../Sming/Wiring/Stream.cpp
C+ ../Sming/Wiring/Print.cpp
C+ ../Sming/Wiring/I2cMaster.cpp
C+ ../Sming/Wiring/IPAddress.cpp
C+ ../Sming/SmingCore/SPI.cpp
C+ ../Sming/SmingCore/HardwareSerial.cpp
C+ ../Sming/SmingCore/DataSourceStream.cpp
C+ ../Sming/SmingCore/Wire.cpp
C+ ../Sming/SmingCore/Clock.cpp
C+ ../Sming/SmingCore/PWM.cpp
C+ ../Sming/SmingCore/Digital.cpp
C+ ../Sming/SmingCore/Interrupts.cpp
C+ ../Sming/SmingCore/ESP8266EX.cpp
C+ ../Sming/SmingCore/FileSystem.cpp
C+ ../Sming/SmingCore/Timer.cpp
C+ ../Sming/SmingCore/Network/HttpServerConnection.cpp
C+ ../Sming/SmingCore/Network/FTPServer.cpp
In file included from ../Sming/SmingCore/Network/FTPServer.cpp:12:0:
../Sming/SmingCore/Network/FTPServerConnection.h: In member function 'virtual bool FTPServer:
nCommand(String, String, FTPServerConnection&)':
../Sming/SmingCore/Network/FTPServerConnection.h:34:15: error: 'virtual void FTPServerConnection::response(int, String)' is protected
virtual void response(int code, String text = "");
../Sming/SmingCore/Network/FTPServer.cpp:51:63: error: within this context
connection.response(200, "File system successfully formated");
C:/Sming-master/HttpServer_Bootstrap/Makefile:329: recipe for target 'out/build/../Sming/SmingCore/Network/FTPServer.o' failed
mingw32-make.exe: *** [out/build/../Sming/SmingCore/Network/FTPServer.o] Error 1
11:50:47 Build Finished (took 9s.905ms)
