bolwoi
Скажите, а каков диапазон и шаг частоты работы I2C ?
И еще порция приходов по UDP.
char ClientIPMask[] = "192.168.100.255";
unsigned int ClientPort = 53333;
unsigned int localPort = 55123;      // local port to listen on
byte packetBuffer[255]; //buffer to hold incoming packet
char  ReplyBuffer[] = "acknowledged";       // a string to send back
byte OutBuf [10] = {0};
WiFiUDP Udp;
byte value = 0;
int packetSize = 0;
int i = 0;
  Serial.setDebugOutput(true); // <- в функции setup, после Serial.begin
  WiFi.mode(WIFI_STA);//: выбрать режим WIFI_AP (точка доступа), WIFI_STA (клиент), илиr WIFI_AP_STA (оба режима одновременно).
  Serial.println("BEGINING");
  WiFi.begin(ssid, pass);
  while ( WiFi.status() != WL_CONNECTED)
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    delay(3000);
  Serial.println("Connected to wifi");
  printWifiStatus();
  delay (10);
  Udp.begin(localPort);
  delay (10);}
void loop()
  packetSize = Udp.parsePacket();
  if (packetSize)
    Serial.print("Received packet of size ");   Serial.print(packetSize);   Serial.print("From ");
    IPAddress remoteIp = Udp.remoteIP();        Serial.print(remoteIp);     Serial.print(", port ");
    Serial.println(Udp.remotePort());
    int len = Udp.read(packetBuffer, 255);
    Serial.print("Contents: ");    Serial.print(len );    Serial.println("Bytes");
    for (i = 0; i <= 3; i++)  { Serial.print(packetBuffer[i]); Serial.print("   "); }   Serial.println(packetBuffer[4]);
    Serial.println(system_get_free_heap_size());
  OutBuf[0] = value;   OutBuf[1] = value+1;   OutBuf[2] = value+2;   OutBuf[3] = value+3;   OutBuf[4] = value+4;  OutBuf[5] = value+5;
  OutBuf[6] = value+6;  OutBuf[7] = value+7;  OutBuf[8] = value+8;  OutBuf[9] = value+9;
/* Udp.beginPacket("192.168.100.255", 53333);
  Udp.write(OutBuf, 10);
  Udp.endPacket();  */
  value++;
  delay (250);
// Serial.println(system_get_free_heap_size());
void printWifiStatus()
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
Лог:
Attempting to connect to SSID: TP-LINK_7D9E32
ip:192.168.100.18,mask:255.255.255.0,gw:192.168.100.1
Connected to wifi
IP Address: 192.168.100.18
:rn 5
Received packet of size 5From 192.168.100.29, port 58205
:rd 5, 5, 0
Contents: 5Bytes
55   56   57   58   59
34896
:rn 5
:rd 5, 5, 0
Contents: 5Bytes
55   56   57   58   59
34896
:rn 5
:rd 5, 5, 0
Contents: 5Bytes
55   56   57   58   59
34896
Клиент UDP слушает порт 55123, а в программе отображается порт 58205.
Сами данные адекватны.
Есть еще одна непонятка - когда я откоменчиваю строки передачи по UDP, то прием байтов вообще не происходит. То есть при одновременных приеме/передаче пакетов, работает только передача.
igrr
https://github.com/esp8266/Arduino/issues/15 — тут обсуждается тема калибровки функции setClock. Как пишет автор, maximum frequency I got was ~307kHz with set values around 180000-200000.
Т.е. при setClock(180000) будет около 300kHz. А вообще надо промерить, как зависит частота от значения delay, которое используется внутри библиотеки, и зашить в код калибровочные значения. Есть кто-нибудь с осциллографом? :)
Не вижу противоречия — хост 192.168.100.29 пересылает пакет с порта 58205 на ваш порт 55123. 58204 — порт на одной стороне, 55123 — на другой.
Можно лог для этой ситуации? Просто ровно эта проблема была исправлена позавчера, и несколько человек подтвердили, что все окей. Насколько я понимаю, я вам отправил архив с новой версией. Неужели я вчера снова все сломал?..
bolwoi
Это я с протоколом не разобрался, наверное.
Я работаю сейчас на сборной солянке, которую вчера приготовил. Я так понимаю, что той версии сборки, ссылку на которую Вы мне дали, не исправлен баг с отправкой ¿ Тоесть там необходимо поправить файлы из предыдущих постов¿
Лог, в принципе, ничего полезного ее показывает. Только то, что отправляются данные, и все. А то, что принимаются - ни слова.
igrr
@bolwoi да, тогда нужно заменить еще те три файла, что я прикреплял выше (WifiUdp.h, .cpp, UdpContext.h).
bolwoi
Скачал последнюю версию (по последней ссылке), заменил там три выше указанных файла.
Та же проблема с одновременными приемом и передачей (коменчу передачу, тогда принимает).
Telek
Проверил последний билд. sqrt заработал, pow дает ошибку
d:/arduino-1.6.1/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\jd\AppData\Local\Temp\build531319777593055206.tmp/sketch_apr14b.cpp.elf section `.text' will not fit in region `iram1_0_seg'
Ошибка компиляции
Telek
Еще непонятный момент. Использую WiFiClient(Ниже часть кода).
Иногда случается так, что ответ на GET запрос не приходит. После этого в моем случае пропадает 168 байт оперативы. По идее, этот client должен позже отвалиться по таймауту и освободить память, но этого судя по всему не происходит. Как с этим бороться?
 if (!client.connect(host, httpPort)) {
    HostConnectionFailedCount++;
    return;
  client.print(url + "\r\n");
  Serial.print("Wait");
  int wait_cnt=0;
  // Жду до 20 сек, а вдруг всеже прийдет ответ
  while ((!client.available()) && (wait_cnt<40)){
    Serial.print(".");
    wait_cnt++;
    delay(500);
  Serial.println();
  if (wait_cnt>=40){
    Serial.println("wait_cnt 40");
  // Читаем что пришло(если пришло)
  while (client.available()) {
    Serial.print("-");
    String line = client.readStringUntil('\r');
    Serial.print(line);
  // Разрываем соединение
  client.stop();
  // Смотрим сколько памяти осталось
Лог(он слегка от другой версии, но основаная проблема видна). Число после "closing connection" это размер доступной памяти.
connecting to 184.106.153.149
Requesting URL: GET /update?key=xxx&field1=735.87&field2=23.90&field3=0&field4=0&field5=0&field6=34832
Wait
-1163 // Ответ получен
closing connection
35232
Requesting URL: GET /update?key=xxx&field1=735.82&field2=24.0&field3=0&field4=0&field5=3&field6=34320
Wait
wait_cnt 20 // Тут ответ не получен, и ниже видно что уменьшился объем
closing connection
35064
Requesting URL: GET /update?key=xxx&field1=735.84&field2=24.10&field3=0&field4=0&field5=0&field6=34544
Wait
-1165  // Ответ получен
closing connection
35064
Это все крутится в основном цикле. В нормальной ситуации объем свободной памяти стабилен. Но в случае отсутствия ответа client похоже "висит" вечно.
client.stop() - что делает в данной ситуации?
UPD. Вроде полечил. Сам дурак - каким-то образом закинул объявление переменной WiFiClient client в глобальные...
UPD2. Не починилось. Если ответ не приходит, то объем свободной памяти уменьшается.
UPD3. Потеря памяти после неполучения ответа проявляется стабильно в билде 67 с билдсервера. В релизе с githab(ссылка на который выложена в первом собщении этого топика) данная ошибка не проявляется - объем свободной памяти остается стабильным.
jcmvbkbc
Я так понимаю, что там генерятся вспомогательные таблицы для ускорения вычислений.
Нет, там используются степенные ряды.
Может без них как-то?
Логичнее было бы без pow, да и без плавающей точки вообще.
goodwin
Подергал за вымя UDP после внесения вышеописанных поправок:
После
принимаются пакеты предназначенные как для локального IP, выданного DHCP сервером, так и broadcast пакеты "255.255.255.255".
Это хорошо ;)
Вот с broadcast передачей беда:
Udp.beginPacket("255.255.255.255", 4444);
Udp.write(OutBuf, 12);
Udp.endPacket();
В сеть передается пакет с IP адресом назначения "0.0.0.0" и номером порта "0".
Не знаю, косяк ли это библиотеки arduino, либо SDK/LWIP.
Пробовал фунцию endPacketMulticast(IPAddress ip, uint16_t port).
Компилятор на нее ругается (что то с аргументом IPAddress).
Подергал так и сяк новомодную функцию SDK wifi_set_broadcast_if(1); (назначил интерфейс WIFI_STA для передачи UDP).
А хотелось бы broadcast - это одна из фишек, для которой и нужен UDP.
Ну и главное:
Запускаем прослушиваение порта
После передачи хотя бы одного пакета
Udp.beginPacket("192.168.0.2", 4444);
Udp.endPacket();
Слушающий порт затыкается.
На него больше ничего не приходит.
Помогает только вызов Udp.begin(localPort); после каждой передачи.
Это есть нехорошо...
bolwoi
Udp.endPacket();
У меня с маской сети 192.168.100.255 работает.
Жаль, что главный фиксер не может пока нам помочь.
goodwin
мультикаст x.x.x.255 тоже работает. Некорректно посылается именно 255,255,255,255.
bolwoi
igrr, Как нам можно перебороть затык с одновременными приемом/передачей? Куда копать?
sherr
У меня вопрос по сборке -- скачал с Гитхаба , собрал по инструкции, компилятор Xtensa не поставился (оно и понятно, под
Linux 32bit его и нет готового). Рядом собираю esp-open-sdk и переношу папку с компилятором в /home/sherr/Arduino/build/linux/work/hardware/esp8266com - те туда, куда просит Arduino . Поставил разрешение на исполнение всем кому положено ,,,
и ошибка при сборке даже пустого скетча :
Arduino: 1.6.1 (Linux), Плата"Generic ESP8266 Module, 80 MHz, 115200"
as: unrecognized option '--text-section-literals'
Ошибка компиляции.
Подкажите, чего не видит, и где нужные пути настраивать ?
ps и программатора esptool в меню нет .
Udp.endPacket();
udp_sendto(pcb, p_out, IP_ADDR_BROADCAST, SERVER_PORT);
IP_ADDR_BROADCAST = 0xFFFFFFFF;
err_t udp_sendto(struct udp_pcb *pcb, struct pbuf *p, ip_addr_t *dst_ip, u16_t dst_port)
* Send data to a specified address using UDP.
* @param pcb UDP PCB used to send the data.
* @param p chain of pbuf's to be sent.
* @param dst_ip Destination IP address.
* @param dst_port Destination UDP port.
* dst_ip & dst_port are expected to be in the same byte order as in the pcb.
* If the PCB already has a remote address association, it will
* be restored after the data is sent.
PS: DHСP работает (?) - значит LwIP тут не при чем, т.к. он использует broadcast запросы.
sherr
Ошибка компиляции.
Извиняюсь, что цитирую сам себя ---
Где пути - нашел ,,,/platform.txt - там всё в порядке .
Но в этом же файле опция компилятора -mtext-section-literals .
а в ошибке --text-section-literals - это нормально ?
