fps
Это видел. Но у неё форм-фактор какой-то совсем кривой.
Док вы тоже не нашли, как я понял. А реверсить такие китайские поделия - это должна быть сильная мотивация.. )
Памяти сколько там? 4 флеш, 32 озу? (как в A5-V11)
U-Boot 1.1.3 (Nov 6 2012 - 19:35:17)
Board: Ralink APSoC DRAM: 16 MB
relocate_code Pointer at: 80fb4000
spi_wait_nsec: 42
spi device id: ef 40 17 0 0 (40170000)
find flash: W25Q64BV
raspi_read: from:30000 len:1000
.*** Warning - bad CRC, using default environment
Ralink UBoot Version: 3.6.0.0
ASIC 5350_MP (Port5<->None)
DRAM_CONF_FROM: Boot-Strapping
DRAM_TYPE: SDRAM
DRAM_SIZE: 128 Mbits
DRAM_WIDTH: 16 bits
DRAM_TOTAL_WIDTH: 16 bits
TOTAL_MEMORY_SIZE: 16 MBytes
Flash component: SPI Flash
Date:Nov 6 2012 Time:19:35:17
icache: sets:256, ways:4, linesz:32 ,total:32768
dcache: sets:128, ways:4, linesz:32 ,total:16384
##### The CPU freq = 360 MHZ ####
estimate memory size =16 Mbytes
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
7: Load Boot Loader code then write to Flash via Serial.
9: Load Boot Loader code then write to Flash via TFTP.
0
3: System Boot system code via Flash.
## Booting image at bc050000 ...
raspi_read: from:50000 len:40
. Image Name: Linux Kernel Image
Created: 2013-11-27 11:12:02 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 5918970 Bytes = 5.6 MB
Load Address: 80000000
Entry Point: 803c6000
raspi_read: from:50040 len:5a50fa
........................................................................................... Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
No initrd
## Transferring control to Linux (at address 803c6000) ...
## Giving linux memsize in MB, 16
Starting kernel ...
LINUX started...
THIS IS ASIC
RT5350 # ?
? - alias for 'help'
bootm - boot application image from memory
cp - memory copy
erase - erase SPI FLASH memory
go - start application at address 'addr'
help - print online help
loadb - load binary file over serial line (kermit mode)
md - memory display
mdio - Ralink PHY register R/W command !!
mm - memory modify (auto-incrementing)
mw - memory write (fill)
nm - memory modify (constant address)
printenv- print environment variables
reg - read/write rf register
reset - Perform RESET of the CPU
rf - read/write rf register
saveenv - save environment variables to persistent storage
setenv - set environment variables
tftpboot- boot image via network using TFTP protocol
version - print monitor version
Что там реверсить?Док вы тоже не нашли, как я понял. А реверсить такие китайские поделия - это должна быть сильная мотивация.. )
Буду признателен за ссылку. По поиску в Google слишком много мусора выдает... А на www.bekencorp.com никак не могу зайти... В https://github.com/bekencorp у них для этих чипов тоже пусто.SDK к чипам есть
А смысл? Туда надо ещё 2 роутера (ретранслятора) ставить?
Зачем еще 2 роутера?А смысл? Туда надо ещё 2 роутера (ретранслятора) ставить?
LE Long Range бьет раза в два дальше WiFi.
Кто-нибудь знает, какой USB BT точно заработает в openWRT? Вот у меня два есть, ни один не работает. Первый выдает вот такое:Самое простое - берете нормальную современную платку с Linux. Пихаете в её USB BT адаптер за 78 руб CSR8510A10 или RTL8761BU (если нужна дальняя связь) с али.
Туда на Python пишите что вам нужно с отсылкой в MQTT в Home Assistant.
Пример маленькой нормальной платки с Linux и Ethernet - Luckfox Pico-M-256MB - ARM Cortex-A7, 256MB Memory, USB работает в две стороны, SD карта в неё вставляется. Есть без разъема Eth. но выводы для подключения есть.
Далее вариантов море и тут надо уже конкретизировать.
Ядро у этой сборки 5.15.134Наверно заработает USB\VID_0BDA&PID_8771&REV_0200 (RTL8761BU), если поменяете загружаемые бинарные файлы firmware к нему.
И CSR8510A10, если не поддельный, имеющий BT4.2, не выше.
Больше наверно на вашем OpenWRT ничего не заработает.
Ныне ядро 6.8 https://www.kernel.org/
