MQTTwarn
Michael Kokorev
Начал работать и формируется mqttwarn.log, который кроме всего прочего фиксирует передаваемые mqtt сообщения, но указанный в 'mqttwarn.ini' файл для формирования лога так и не создается...
уберите в последней строке mqttwarn.ini [inline]smtp:notify, [/inline], т.к. сервис smtp у вас не прописан
Michael Kokorev
И вот опять вопрос:
2015-09-02 19:12:33,669 DEBUG [mqttwarn] Message received on /ESP8266/DATA: {"micros":784060,"counter":78}
2015-09-02 19:12:33,690 DEBUG [mqttwarn] Section [/ESP8266/DATA] matches message on /ESP8266/DATA. Processing...
2015-09-02 19:12:33,722 DEBUG [mqttwarn] Message on /ESP8266/DATA going to log:info
2015-09-02 19:12:33,741 DEBUG [mqttwarn] New `log:info' job: /ESP8266/DATA
2015-09-02 19:12:33,762 DEBUG [mqttwarn] Processor is handling: `log' for info
2015-09-02 19:12:33,781 DEBUG [mqttwarn] Message on /ESP8266/DATA going to file:data
2015-09-02 19:12:33,791 DEBUG [mqttwarn] New `file:data' job: /ESP8266/DATA
2015-09-02 19:12:33,833 DEBUG [log] *** MODULE=services/log.py: service=log, target=info
2015-09-02 19:12:33,820 DEBUG [mqttwarn] Message on /ESP8266/DATA going to http:thingspeak
2015-09-02 19:12:33,862 INFO  [log] {"micros":784060,"counter":78}
2015-09-02 19:12:33,861 DEBUG [mqttwarn] New `http:thingspeak' job: /ESP8266/DATA
2015-09-02 19:12:33,892 DEBUG [mqttwarn] Processor is handling: `file' for data
2015-09-02 19:12:33,880 DEBUG [mqttwarn] Message on /ESP8266/DATA going to instapush:alerts
2015-09-02 19:12:33,932 DEBUG [mqttwarn] New `instapush:alerts' job: /ESP8266/DATA
2015-09-02 19:12:33,951 DEBUG [file] *** MODULE=services/file.py: service=file, target=data
2015-09-02 19:12:33,967 DEBUG [mqttwarn] Processor is handling: `http' for thingspeak
2015-09-02 19:12:33,999 DEBUG [http] *** MODULE=services/http.py: service=http, target=thingspeak
2015-09-02 19:12:34,423 DEBUG [mqttwarn] Processor is handling: `instapush' for alerts
2015-09-02 19:12:34,467 DEBUG [instapush] *** MODULE=services/instapush.py: service=instapush, target=alerts
2015-09-02 19:12:35,189 ERROR [mqttwarn] Cannot invoke service for `instapush': <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] unknown error (_ssl.c:581)>
2015-09-02 19:12:35,210 WARNING [mqttwarn] Notification of instapush for `/ESP8266/DATA' FAILED
Так выглядит фрагмент моего mqttwarn.log файла. Из которого следует, что instapush вообще не вызывается. Есть ли какие либо советы на этот счёт??
Stas43
Есть ли у кого опыт запуска mqttwarn на Ubuntu server?
Конкретно интересует запуск как демона из /etc/init.d/mqttwarn
Stas43
Запуск mqttwarn на Ubuntu server 14.04
Данное руководство создано на основе информации с этого сайта
http://esp8266.ru/esp8266-openwrt-mosquitto-mqttwarn-thingspeak-email-android-ios-twitter-cloudmqtt/
Я только отладил start-stop его как сервиса. Прилагаемые примеры в исходниках у меня не работали:(
1. Скачиваем архив mqttwarn:
wget https://github.com/jpmens/mqttwarn/archive/master.zip
2. Распаковываем в любое место.
3. Устанавливаем недостающие модули:
sudo apt-get install python
sudo apt-get install python-distutils
sudo apt-get install python-email
sudo apt-get install python-logging
sudo apt-get install python-ncurses
sudo apt-get install python-openssl
sudo apt-get install python-pip
sudo pip install paho-mqtt
sudo apt-get install ca-certificates
4. Создаем папку /etc/mqttwarn
копируем в нее из ранее скачанного архива:
папку /services
mqttwarn.py
5. Создаем файл /etc/init.d/mqttwarn следующего содержания
#!/bin/sh
### BEGIN INIT INFO
# Provides: mqttwarn
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: mqttwarn
# Description: mqttwarn
### END INIT INFO
set -e
NAME=mqttwarn
DAEMON=mqttwarn.py
PIDFILE=/var/run/mqttwarn.pid
. /lib/lsb/init-functions
perform_start()
log_daemon_msg «Starting $NAME»
if start-stop-daemon --start --quiet --chroot / --chdir /etc/mqttwarn --oknodo --background --make-pidfile --pidfile ${PIDFILE} --exec ${DAEMON} ; then
log_end_msg 0
return 0
else
log_end_msg 1
return 1
fi
perform_stop()
log_daemon_msg «Stopping $NAME»
if start-stop-daemon --stop --quiet --oknodo --pidfile ${PIDFILE}; then
log_end_msg 0
rm -f ${PIDFILE}
return 0
else
log_end_msg 1
return 1
fi
case "$1" in
start)
perform_start
stop)
perform_stop
echo "Usage: /etc/init.d/$NAME {start|stop}"
exit 3
esac
и даем ему права 755 root root
6. Выполняем в терминале команду:
sudo update-rc.d myscript start 99 2 3 4 5 . stop 01 0 1 6 .
7. Создаем файл /etc/mqttwarn/mqttwarn.ini - пример есть на этом сайте, повторять не буду.
8. Пробуем сервис запустить и остановить.
sudo /etc/init.d/mqttwarn start
- должен появиться лог файл (/etc/mqttwarn/mqttwarn.log), если его не было и pid файл (/var/run/mqttwarn.pid). В pid файле указан номер процесса, под которым работает демон (python). По этому номеру он виден и по top
sudo /etc/init.d/mqttwarn stop
- процесс пропадет, pid файл удален.
Перезагружаемся. Mqttwarn должен стартануть автоматом (если не опечатались в п.6)
Всё.
Stas43
Дополнения к исходной статье (http://esp8266.ru/esp8266-openwrt-mosquitto-mqttwarn-thingspeak-email-android-ios-twitter-cloudmqtt/)
В примере, для отправки уведомления по e-mail, указан следующий конфиг (вырезка):
[config:smtp]
server='smtp.mail.ru:25'
sender="MQTTwarn "
username=esp8266@mail.ru
password=xxxxxxxxxxxxxxxx
starttls=True
targets={
'notify' :['4refr0nt@gmail.com']
У меня такая конфигурация давала отказ smtp.mail.ru сервера:
2015-09-06 22:04:15,648 WARNING [smtp] Error sending notification to SMTP recipient notify [['admin@*******.ru']]: {'admin@*******.ru': (501, 'sender address must match authenticated user')}
Уведомления стали отсылаться только после исправления строки senders . Конкретно для примера выше:
sender="esp8266@mail.ru"
и ничего более!
FedorDostoevsky
Запускаю mqttwarn на TP-Link MR3020 с разделом swap на USB Оперативной памяти в роутере действительно надо 64 мегабайта. В дополнение к материалу статьи:
Экспорт в таблицы Google docs spreadsheets заработал через gss2.py, который недавно появлся в git mqttwar
Видимо, красавцы из Google переделали авторизацию, и теперь чтобы получить конфиг, нужно пройти квест.
Настройки выглядят так:
[config:gss2]
timeout = 20 ; с таймаутом не разбрался.
client_secrets_filename = client_secrets.json
oauth2_code = 4/Ygygsklsjfiefj89ue89fwhcwhcniuw-c
oauth2_storage_filename = oauth2.store
targets = {
# spreadsheet_url # worksheet_name
'test': [ 'https://docs.google.com/spreadsheets/d/HrKHrhrjrjiiieuu2984shvskvhsuhvv/edit#gid=0', 'Sheet1']
# This target would be addressed as 'gss2:test'.
До формата отправки тоже не сразу допёр, но потом сделал по образцу gss.py
mosquitto_pub -t clients/spreadsheet -m '{"counter":"125"}' -u test -P test
Для gss,py не удалось поставить пакеты python из-за ошибки в pip install gdata-python-client. Может быть, не хватило памяти
(gcc, например, штатно не поставился из-за размера пакета).
Jon811
Всем доброго дня!
У меня DIR-320NRU с USB-картой, всё сконфигурировано.
Установил mosquitto - все завелось, mqttspy подключается.
Попробовал отправить данные через mqttspy на instapush - ничего не происходит, в системном логе:
Wed Jul 13 10:55:49 2016 local5.debug mosquitto[1126]: Received PUBLISH from project_161606211 (d0, q0, r0, m0, '/ESP8266/DATA', ... (13 bytes))
Wed Jul 13 10:55:49 2016 local5.debug mosquitto[1126]: Sending PUBLISH to project_161606211 (d0, q0, r0, m0, '/ESP8266/DATA', ... (13 bytes))
При попытке перезапуска mqttwarn в system log появляется запись: Wed Jul 13 11:37:05 2016 daemon.err uhttpd[1115]: start-stop-daemon: warning: killing process 3600: No such process
Log файл не формируется (в паке /overlay/mosquitto новых файлов нет).
Кто подскажет куда копать можно?
mqttwarn.ini:
[defaults]
hostname = 'localhost'
port = 1883
username = test
password = test
clientid = 'mqttwarn'
lwt = 'clients/mqttwarn'
skipretained = False
cleansession = True
# MQTTv31 = 3 (default)
# MQTTv311 = 4
protocol = 3
; logging
logformat = '%(asctime)-15s %(levelname)-5s [%(module)s] %(message)s'
logfile = 'mqttwarn.log'
; one of: CRITICAL, DEBUG, ERROR, INFO, WARN
loglevel = DEBUG
; name the service providers you will be using.
launch = file, log, instapush, smtp, http, twitter
[config:file]
append_newline = True
targets = {
'data' : ['/overlay/mosquitto/mqtt-data.log'],
'mqttwarn' : ['/overlay/mosquitto/mqttwarn.err'],
[config:log]
targets = {
'info' : [ 'info' ],
'warn' : [ 'warn' ],
'crit' : [ 'crit' ],
'error' : [ 'error' ]
; special config for 'failover' events
[failover]
targets = log:error, file:mqttwarn
[config:instapush]
appid = '1111111111111111111'
appsecret = '222222222222222222222'
targets = {
# event # tracker
'alerts' : [ 'alerts', {"object":"counter", "action":'{counter}'}],
'gpio' : [ 'gpio' , {"status":'{status}'}]
[/ESP8266/DATA]
targets = instapush:alerts
alfa2
Добрый, Гуру
Установлено OpenWrt Chaos Calmer 15.05.1 / LuCI 15.05-149-g0d8bbd2 Release (git-15.363.78009-956be55)
монтируется USB с тремя разделами: /Overlay, /USB, /Swap
Установлены все рекомендуемые в статье пакеты
мosquitto работает
mqtt-spy подключается, топики # видно, информация поступает
а вот mqttwarn ни как не хочет работать
Мои файлы
/overlay/mosquitto/
mqttwarn.ini
[defaults]
port = '1883'
username = 'esp8266'
password = 'хххххххх'
cleansession = True
protocol = 3
loglevel = DEBUG
launch = file, log, http
[config:file]
targets = {
[config:log]
targets = {
[failover]
mqttwarn.ry
из архива. без изменений
/etc/init.d/mqttwar chmod 100755
#!/bin/sh /etc/rc.common
# Script to start mqttwarn as a daemon for OpenWRT
START=95
STOP=10
DIR='/overlay/mosquitto/'
BIN='/overlay/mosquitto/mqttwarn.py'
start() {
echo start
cd $DIR
start-stop-daemon -b -S -q -m -p $PIDFILE -x $BIN
stop() {
echo stop
start-stop-daemon -K -q -p $PIDFILE
rm -f $PIDFILE
Системный журнал:
Sun Nov 13 20:22:25 2016 daemon.err uhttpd[1222]: 1479057745: mosquitto version 1.4.7 (build date 2016-01-31 13:11:04+0100) starting
Sun Nov 13 20:22:25 2016 daemon.err uhttpd[1222]: 1479057745: Using default config.
Sun Nov 13 20:22:25 2016 daemon.err uhttpd[1222]: 1479057745: Opening ipv6 listen socket on port 1883.
файлы логов: mqttwarn.log mqtt-data.log mqttwarn.err не создаются
проверяю работу mqttwarn
root@OpenWrt:~# ps | grep mqttwarn
2373 root 1356 S grep mqttwarn
root@OpenWrt:~#
paho-mqtt установлен
Если запустить:
root@OpenWrt:~#cd /overlay/mosquitto/
root@OpenWrt:~#/usr/bin/python /overlay/mosquitto/mqttwarn.py
Системный журнал:
Sun Nov 13 21:45:59 2016 user.emerg syslog: 1479062759: New connection from 127.0.0.1 on port 1883.
Sun Nov 13 21:45:59 2016 user.emerg syslog: 1479062759: New client connected from 127.0.0.1 as mqttwarn (c1, k60, u'esp8266').
Sun Nov 13 21:46:35 2016 daemon.info hostapd: wlan0: STA 5c:cf:7f:c2:f8:a6 WPA: group key handshake completed (RSN)
создается топик clients/mqttwarn (смотрю mqtt-spy)
создается файл лога mqttwarn.log
2016-11-13 21:49:35,847 INFO [mqttwarn] Starting mqttwarn
2016-11-13 21:49:35,851 INFO [mqttwarn] Log level is DEBUG
2016-11-13 21:49:35,883 DEBUG [mqttwarn] Service file loaded
2016-11-13 21:49:35,902 DEBUG [mqttwarn] Service log loaded
2016-11-13 21:49:38,669 DEBUG [mqttwarn] Service http loaded
где я не прав?
dao89
Файлы '/overlay/mosquitto/mqtt-data.log' и '/overlay/mosquitto/mqttwarn.err' сами собой и не создадутся, пока вы не укажите из какого топика нужно класть туда данные.
Попробуйте в ini файл добавить
[/myTopic]
targets = file:data
Затем перезапустите mqttwarn и через mqtt-spy пошлите сообщение в топик /myTopic
Файл /overlay/mosquitto/mqtt-data.log должен появиться, каждая строчка в нём - сообщения, которые отправите в /myTopic
Я бы рекомендовал посмотреть readme, который лежит рядом с mqttwarn.py: там в начале как раз приводится пример с file.
